danceMB said:Are you running your P3.2 @ stock levels by any chance? With that mobo you should be able to have some overclocks which, in theory, should give you higher scores. I have a IC7 Max 3, and at the moment im on 3.36, will go to at least 3.6 when I get my new air cooling put on, as the stock heatsink that I have is really quite useless.
danceMB said:I did get a connector with 2-3 pin molex connectors (1 pin was removed from each) and the 6-pin connector to go into the graphics card.
The question is, where do those 2 3-pin molex connectors plug into?
Lol, dude you are being paranoiddanceMB said:I need to know which 2 molex connectors to use. I have a Tagan 480, and there are several spare molex connectors hanging around inside, is it just a case of using any 2 connectors that are free?
At the moment I have a Gainward 6800GT, and it is plugged into a blue coloured molex with "VGA CARD" on it, but I only have 1 of those. Shall I use that as molex connector 1, and just any other molex for connector 2?
I just need to make sure as I dont want to be doing any wrong connections for such an expensive piece of hardware. Tell me if im being paranoid![]()
Don`t really know if there is any difference between between the vga and other molexs` as far as the output is concerned, the thicker one + insulation could just be that way to make it `look` different from the othersdanceMB said:I was just being curious really, as that VGA card cable is a very thick one that has its own insulation, where all the other molex's just have strands of different wire.
Yep & yepdanceMB said:Can this card perform as high as a 7900GT PCI-e? Or even high er due to its "Golden Sample" enhancements?
