You need to check what your ping is to the ISP - if it is more than this or close to it you'll cause yourself a whole load of grief.
Look at it another way - no other router does this on an ADSL line so use auto first - see how it works out and then start playing with the ping settings. The gargoyle status on the qos screen is pretty good at showing what the router is doing
Also bear in mind upload can also effect this so mak sure upload qos is also set
