- 7 May 2021
- London
Okay so I asked the garage to email me their diagnosis.
On inspection the vehicle has been fitted with new front brake pads at some point with an obscene amount of cooper grease on the brake pad sliders.
This has made its way on to the brake discs and contaminated them to the point when warm not being able to brake efficiently.
Copper grease should not be used on modern braking systems as copper and aluminium brake caliper carrier do not mix well and the amount used is here is very excessive.
The vehicle also has a sticking nsr brake caliper which will need to be replaced and the brake fluid in the vehicle is at 5% water content which will also need to be replaced.
So to rectify the vehicle it requires:
New front brake disc and pads
Brake fluid change
Nsr brake caliper
Brake fluid change
Nsr brake caliper
