Hi,
I'm looking to upgrade my two 1080ti for the new 3000 series and I'm currently in between the 3080, 3080ti and 3090. My main question is if these would be fully compatible with my system and if they'd fit inside the GPU slots since the 3000 series are quite larger than the previous ones. Initially, I'm looking to get two new GPUs to replace the 2x1080ti I have atm but if that turns out to be a bit too much for my current rig I might go with one of the superior end of the series like a 3080ti or 3090.
My current rig has:
AMD Ryzen™ 7 1700X, S AM4, 8 Core, 16 Thread,3.4GHz, 3.8GHz Turbo, 16MB Cache, 95W
ASUS ROG CROSSHAIR VI HERO, AMD X370, S AM4,DDR4, SATA3, M.2 (PCIe/SATA), 2-Way SLi/CrossFire,GbE
2x EVGA GeForce GTX 1080 Ti SC Black Edition GAMING11GB GDDR5X VR Ready Graphics Card, 3584 Core,1556MHz, 1670MHz
NZXT S340 Elite Desktop Computer Chassis, Mid Tower,Side Window, HDMI, 2x USB 3.0, mITX/mATX/ATX
Corsair Hydro Series H80i V2 All-In-One ExtremePerformance CPU Cooler with 120mm Radiator, 2x120mm Fan, Intel/AMD, TR4
My current rig has:
