I live in an old house that has a twin copper ohone wire coming in, attaches to what looks like a small bell box on the wall, then continues on to the master socket.
Unfortunately, my ex-wolf hybrid ripped the phone line off the wall, and I was forced to use some extension cable to replace the chewed stuff. There are also existing issues with the mastersocket anyway, so I'd like to replace that entirely.
So... where is best to get replacement boxes for the main 'bell box' (not sure of the technical name), and the master socket. If possible, I would like something as good as the BT Openworld filtered box, or something from say solwise that is better.
I have looked, but frankly, I'm a little unsure of what parts would 100% work.
(And yes, I realise about BT having ownership of all the part's upto and including the master socket, but it's already screwed anyway from the dog ripping the cable out before the master socket).
The main reason for doing all this btw, is because the master socket is now so loose it keeps cutting out, which reduces my rate eventually down from 1.3Mbps to about 0.125Mbps.. and that's even running through a jury rigged BT filter to help the signal.
Very old!
(Another reason I'd like to get it sorted).
