Man of Honour
- 23 Mar 2011
- West Side
It's a pointless upgrade letting the new ram run at 2400mhz.So just forget the ram and return it?
Send them back if your not going to use them and upgrade if you change platform.
After his recent experience I would be reluctant to go threw all that again.check how high it will let you clock.. 2400mhz is base spec so it should run..
you might be able to use the full potential when you upgrade in the future
