It was not possible to install the F3 BIOS due to ID errors.Hey Flight404 were you finally able to flash your card to the new F3L bios version? I've just tried to do it on mine today and I got the same problem, Gigabyte VGA@BIOS tool gives me an ID error.
I've also contacted Gigabyte (again) as they were recommending to flash to the new version...
I had it with Gigabyte. The card went 84 degrees celsius and throttling back to mid 700MHz, with a fanspeed of 54% (this started to get loud)
I mailed Gigabyte and the come with the answer:
Please install the VGA@bios Tool and check the installed bios version of your card.
Please note:
You can only update to a VBIOS version of the same series.
If your VBIOS version is:
F1, it can only be updated with VBIOS versions F2-F9.
F10, it can only be updated with VBIOS versions F11-F19.
F20, it can only be updated with VBIOS versions F21-F29.
This is a big fail because the F3 BIOS is the first BIOS update for that card.
So I went back to the store where I bought the card and I replaced it with the Sapphire R9 290 TRI-X OC.
This card is way better then the Gigabyte.
Performed some benchmarks with the Sapphire R9 290 TRI-X OC:
- No throttling
- 74 degrees celsius on 1920x1080 8x MSAA
- Fans quit at 42%
- VRM1: 73 degrees celsius, VRM2: 57 degrees celsius
The Gigabyte R9 290 WINDFROCE:
- Throttling to mid 700MHz
- 84 degrees celsius on 1920x1080 8x MSAA
- Fans way louder at 52%
- VRM1: 120 degrees celsius, VRM2: 66 degrees celsius
