You need a displayport or HDMI cable then yes it supports the audio from the monitor. I had one of those monitors (before I returned it the next day for a refund under DSR) hooked up to my MSI GTX 780Ti via Display Port & HDMI the sound quality is very poor due to the low quality speakers in the TV but you can always use the headphone socket on the TV as that will read the audio from the GTX 780 Ti.Will i be able to use 2560x1080 with the Resolution Asus SonicMaster MX299Q 29" Ultra Widescreen Ultra Slim Bezel LED Monitor?
I read somewhere that it only supports the Res on DVI. Does this mean no sound, only images? Thus no gaming?
21:9 aspect ratio is very poorly supported in most recent games. The majority are hard coded for 16:9 aspect ratios so unless you select 1920x1080 & play with the large black bars either side the image looks odd.Can i ask why you returned this? Am i going to be disappointed with it? Not that im going to use the monitor speakers but with them being of poor quality, does not bode well for the rest of the monitor?
Either of these 2 would be ok. They will be strong enough but if you can afford it look at paying around £130-150 for a stronger PSU if your going to overclock.Think I may have made a booboo with this graphics card.
Can anyone confirm if this psu is compatible with it? It's only got 6 pin PCI but the gpu comes with the correct cables. Every time I try yup stress test, my machine cuts out.
http://microdream.co.uk/pc-componen...-nps-750ab-1-b-atx-750w-psu-power-supply.html
If not, can anyone recommend a upgrade as it's well due. My mb is a gigabyte
