Gigabyte Help
26 Mar 2009
I have recently bought a Gigabyte GA-H61M-D2-B3 mobo and built a system with a gainward graphics card 1gig version (I dont know the model number but it supports HDMI output)
Everything was working apart from the HDMI and sound output through it. I realise the spdiff connection should be made but I cannot find it. Had a look around a bit took the graphics card out and back in. And now my system wont even power up.
If anyone has any suggestions I would be gratefull.
Have you checked all components are fully seated?
power connections to mobo, 24 pin + 4/8 pin?
power to graphics card 2 x 6 pin?
Spdiff may be an option on that board requiring a seperate riser?
Is power supply good?
Is there output from the dvi port, on board graphics?
andy.
I have checked all the connections on the motherboard and all seems well however. I havent checked the power supply so that is the next step.
I havent tried resetting the cmos so I will try that later today.
when you say it won't power up, do you mean no fans spin etc ?
as for hdmi and sound output through it did you change the output setting to use hdmi ?
