- 23 Mar 2010
awesome keyboard and mouse, really liking it
I think they go more for looks than build qaulity.
Wish OCUK would stock the brown keys with white backlighting. I would buy the keyboard now if they did
Very nice.
Wish OCUK would stock the brown keys with white backlighting. I would buy the keyboard now if they did![]()
I get that very occasionally, one of the reasons i'm tempted by a Shine III...Oh and the other problem, again documented elsewhere, it seems to "stick" sometimes, Ie you press x once and this happens: xxxxxxxxxxxxxxxxxxxxxxx until you press another key. It is not an occasional problem either.
Great review, however there are some issues with the keyboard not mentioned.
If you leave a mobile phone next to it, it stops working. Supposedly due to interference, you need to make sure it is atleast a foot away.
It requires a pair of USB ports in your computer to function, one of them is simply for the Alivia logo to power up, but the whole keyboard won't work without it.
The software is appalling on Win7 x64, it doesn't save macros properly and the Alivia logo always resets on boot to a torquoise color which does not match the keyboard. It also stays lit up when you turn your PC off unless at the wall, or turn off the illumination via the toggles unlike the rest of the keyboard which turns off properly.
Pushing the alivia button does nothing on my model. I thought it was faulty but a web search reveals ton's of problems for this keyboard, so do your due dilligence before trusting the reviews
