I like SRADs, I'd have said get an old CBR600F if you have to have a sports bike, they're indestructible and cheap... But the SRAD 600 still isn't a bad choice. Some people need a slow bike to rein them in when they're new, others don't, that's just something you'll find out yourself. Just take it easy for the first 20 years and you'll be fine
But definately do get crash bungs, they're not just for the big crashes, they're also for when you don't put the stand down right, or you put your foot in a pothole at the traffic lights, or someone reverses into it when it's parked. Good ones make all the difference.
No Bandit's ever had a detuned GSXR engine, the original was based around the GSX600F engine. It's got some GSXR750 DNA from the but it's by no means a GSXR engine. And the new one's purpose built for the Bandit.
But definately do get crash bungs, they're not just for the big crashes, they're also for when you don't put the stand down right, or you put your foot in a pothole at the traffic lights, or someone reverses into it when it's parked. Good ones make all the difference.get a bandit 600 or a hornet 600, basically de-tuned and no fairing versions of their sportsbike sisters (gix and CBR)
