- 17 Jun 2005
using the stock remote is usually quicker i find, i have a harmony and never use it.
you simply cannot replace every single button on most remotes. if your simple and don't use advanced features then get a harmony. if you tweak stuff all the time then don't bother.
e.g. i use game mode on my tv a lot, i use smart tv functions on my tv, etc.
i find it's usually easier and quicker to use the 3 separate remotes than have one and have to use the toggle device button
oh and my tv controls my ps4 and my stock remote controls the tv
I'm sure you are aware Sonny but I had a few things like you which I couldn't do initially on my Harmony 650 but worked on them and now have everything working perfectly. I use Game and true cinema on my Panasonic ST50, I have created a macro for cinema mode and one for game mode and they are now on-screen buttons in the bottom right and left corners. It works great I can change between cinema and game mode with the press of one button.
I then have "power toggle" on the upper right corner which means in whatever mode im on i always have access to turning the screen off on its own as often i leave the PS4 on whilst i go start cooking etc =).
Finally the top right button is "stereo toggle" which switchs from stereo only to Dolby PLII at the touch of a button.
All of this took a bit more work and imagination to get it working exactly how i want it but now i works perfectly.
Hope this helps somebody.
My problem is visitors, my kit is in the dining room except for the telly in the front room. The IR is beamed across the living room and thus is interrupted if someone is standing in the way. Perhaps I need to find a very long extension cable!
