God and SQL
God, using SQL, or Basic, or C, or Java? I don't think so. Writing ASCII programs is where it's at... :)
Code:
X5O!P%@AP[4\PZX54(P^)7CC)7}$  Hello World. Having a nice day?  $H+H*
If you have a 32-bit version of Windows handy, you can even try this yourself. Copy the line above into notepad and save it as helloworld.com (should end up as 68 or 70 bytes if you've done it right), then scan it with your Antivirus software (which you do have, right - I take no responsibility for broken systems), and finally, run it. :)
PS - for the tech savvy, you may notice this has more than a passing similarity to the Eicar Antivirus test file (from which it was derived), but hopefully neutered enough that no Antivirus software will barf at it.
Code:
begin
	create table #chavs
		chav_id 	 numeric(10) primary key,
		chav_idiocy	decimal(10,2)
	insert into
		#chavs
	select
	from
		world..t1chav
drop table #chavs
commit transaction
return 0
For added effect :D
crystaline said:
Personally I find it quite hilarious that people are trying to outdo each other on something I scrawled in 1 minute as a joke on Hello World. I mean, actually getting compilers out! :p
All in the name of fun!
Oh god :(
JollyGreen said:
DELETE FROM HumanRace WHERE HumanType = 'Chav'
103,452,382 rows affected
Or for the scottish edt of SQL
DELETE FROM HumanRace WHERE HumanType = 'Ned'
It's a joke, personally I find it amusing how seriously people take things on these forums :)
Code:
if(count_chars($candle) < 2)
	exit($candle);
	exit($candle);
	if(array_walk($life) == shadow && !(money_format($player) == $lots))
		function strut($player, $time, $place)
			$player = array_walk($player)++;
			while($count < $time && $PHP_SELF == $place)
				echo("One Missisipi");
				echo($Player);
				$count++;
		function fret($player)
			$player = mysql_query("SELECT * FROM Things WHERE Good = 'FALSE'");
			return $player;
		strut(fret($player),3600,"Stage");
		$player = null;
		echo($player);
		function toldby($tell, $by)
			$row = mysql_fetch_array(mysql_query("SELECT ".$tell." FROM " . $by))
			echo($row[$tell]);
		$life = toldby("Tale","Idiot");
		$life = null;
Translation:
Out, out, brief candle! Life's but a walking shadow, a poor player That struts and frets his hour upon the stage And then is heard no more. It is a tale Told by an idiot, full of sound and fury, Signifying nothing.
Shakespeare in PHP :p
burnsy2023 said:
Code:
main()
       printf("hello, world");
Burnsy
Its been a while since I did any C but I thought the return type of main should be int, for proper ANSI style c99 complient code. :p
Yeah gcc -
test.c:2: warning: return type of main is not int.
Yeah gcc -
I believe this is where I say "FNAR!"
Code:
Gave me a warning in AVG
