- 4 Jan 2004
- ¯\_(ツ)_/¯
Boxcutter is great, especially when I'm not in the mood for Venetian Snares!Very true, I'z just saying, sometimes getting rid of that annoying little analogue "fizz" can become an expensive hobby
If you're not a massive gamer then try some of the m-audio (midiman) cards. They're reasonably priced, analogue cards as the capacitors they use are of an exceptional quality, which is very important for analogue out (for headphones etc).
The only problem you may get is "compatability" as even though they're doing a fine job as a company and making x64 Vista and x64 Win7 drivers, they're very simple cut-down drivers just for people that still appreciate the fact they were born with 2 ears; which are ideal, for headphones
+ is dat sum Boxcutter john signature![]()
The Xonar cards seem to be a step in the right direction, the m-audio cards are nice also... I use an E-mu 1212m on one of my machines, and while it works great in XP, I have yet to try out W7 so I guess I have that to look forward to. It goes sound great with headphones tho, I find having a quiet computer makes one of the biggest differences if you're using it for audio.
