Sorry to be a pest but would you be able to link me to these coolers that would fit my board and cpu?
Will you be overclocking at all? Not a lot of point in a top end cooler if you aren't
Will you be overclocking at all? Not a lot of point in a top end cooler if you aren't![]()
i doubt that i will only because im not capable.
The skill of over clocking is something you learn, not something your born with (unless you're 8 pack). Its easy to do and safe asking as you research it..
The question is really, do you want to overclock?
Think of it as turning your new Hi Fi up until the speakers start to distort then turning it down and upping the bass until it sounds right
Replace the volume with a CPU multiplier and the bass with voltage then you're about there.
It's pretty simple these days.
If you want to go liquid over air and you're not that worried about getting every single last bit of performance out of your CPU (ie a mild overclock) then go for something like the H60 or the more expensive H80i which is the newer version with adjustable light colours etc.
H100i if you want the top end or the Antec equivalents which are on offer at the moment.
YOUR BASKET
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (Socket 1155 / 1156 / 1366 / 2011 / AM2 / AM3 / FM1 / FM2) £99.98
1 x Antec Kúhler H2O 920 Series 4 High Performance Liquid CPU Cooler (LGA1155 / LGA1156 / LGA1366 / 2011 / AM2 / AM2+ / AM2+ / AM3+) £79.98
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler (Socket LGA1155 / LGA1156 / LGA1366 / LGA2011/ AM2 / AM3 / FM1 / FM2) £76.98
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler (Socket LGA2011 / 1366 / 1155 / 1156 / 775 / AM2 / AM3) £59.99
1 x Antec Kúhler H2O 620 Series 4 CPU Watercooler (Socket Intel LGA 1155 / 1156 / 1366 / 2011 / AMD AM2 / AM3 / AM2+ / AM3+) £44.99
Total : £373.32 (includes shipping : £9.50).
Or you can go air but you would need to watch your ram heatsinks and maybe get low profile ram.
There are plenty of cooling options.
If you're considering playing with overclocking and you have cash to burn then go for the H100i and have some fun playing. There are plenty of guides to help you and plenty of people here that will help.
Edit: The H100i is a really tight fit in the scout case. You may be better going with the smaller rad size coolers
ok so let me get this correct.
I could get the H100i with no intention of overclocking but the option is there if i ever want to? I think this is the way i might go.
Check my edit at the bottom
It's tight in your case but you could still go h80i. I linked a thread with sizes for cases etc
well looks like it might be a new case aswel then,
my head is exploding i didnt realise there was all these variables.
It's so much easier and gives greater options for me. Particularly for watercooling which will be my next project.
