- 21 Dec 2019
- Planet Thanet
And
Loop order is irrelevant
As long as res feeds pump
The loop will reach a state of equilibrium after a time running
Ie so many minutes after pc was turned on
You did do a drain point didn't you
And I know you weren't quite satisfied
With the tubing
So it was always getting drained down lol
As suggested swap cpus
May work out fine for both of you.
If not a 9900k is a really hard cpu to
Reccomend
As no future after 9900k ~ie would be a new motherboard /socket for future path
Would have to Reccomend AMD
Should you go upgrade path
With the tubing
Reccomend
