Anders0n said:Anyone want to help me with my diet?
Should I be going on cutting diet first?
Duradrum said:How tall are you? Do you know your current BF%?
Anders0n said:I'm about 6ft. Not sure what my BF% is atm.
Ideally I'm looking to know how many calories, how much protein, complex carbs, and good fats I should have in my diet. Maybe I should start around 2000 calories a day and see where that gets me? I know exactly what sort of foods I should be eating just not how much of the above.
May thanks.![]()
Duradrum said:I'd aim for around 2300 cals per day, which based on your stats should put you in a calorie reduced diet, mainly sacrificing carbs & fat.
Here is a great guide that I am following myself:
Ripping Up
and some more great reading written by someone far more knowledgable in fitness than me:
Building your house
Give them a read, they provide some excellent information![]()
Cheers mateFusion said:Excellent work mate. Plenty of mass and well defined. Suprised you use creatine though, as I've found it makes you look soft. Unless you're using CEE, which apparently doesn't cause bloat, but I've never tried that.
Anders0n said:The stuff at the bottom of this page?
http://www.sports-nutrition.net/acatalog/whey-protein-products.html
It's just the stuff I was thinking of getting, using the musletalk coupon code to get 2 for £19.99
ethos said:Oh and all-in-1 is just re-badged Reflex as far as I know.
CheersTony Soprano said:Chong Warrior - That is brilliant progress, what height are you?![]()
Jean sizes are useless. Ive had the same sized jeans, one pair can fit me skin tight, and the other is really baggy!Chong Warrior said:The waist is a strange one though, as I can't wear any of my 32" jeans without a belt or they'll fall off...
Anders0n said:Reading about a bit more on HIIT, I've realised I've been doing it drastically wrong. Previously I was doing 4mins on 4mph then 30secs on 8mph.![]()
Going from this site I'll be doing:
Example of a 23-Minute HIIT Treadmill Session
1. Run at 12 mph for 30 seconds to one minute (hands off!)
2. Walk easy for two minutes.
3. Repeat cycle seven more times.
4. If the work interval doesn’t fry you, use a slight grade.
5. Or, run at 6 or more mph at 15 percent incline.
Any chance that someone could answer some of my other questions above?
Many thanks![]()
Duradrum said:That sounds fine. When I do HIIT I run full pelt for 25 secs, wait until my heart rate hits 185-190 bpm, then slow down to walking pace, wait for heart rate to drop to 130bpm, walk at this pace for 2 mins then run full pelt again.
I would really recommend you start weights though for more effective fat loss.
