What kind of mounts are people using for GPS?
If you are looking for something really neat you could do a lot worse than the Techmount Stem Mount.
I bought one for my Zumo 660 and it positions the unit in just the right place. It's neat too. Here's a pic without the Zumo.
You can order it with the correct baseplate fitted for the 660. Quality is superb and there's a UK supplier. Recommended.
. That's how I had my GPS mounted for a while while I was waiting for my yoke fitting to come hah.
