Interesting mainboard temp is still high, however, if this was the real temperature motherboard should cut off at 100C anyway. PSU holds seems to hold its voltage well and if you have a quality 550w psu it should be enough for rx 380 and your cpu as it should pull more than 300W.
Your temps would suggest that your pc is relatively clean and with good enough airflow. Have you tried to reinstall drivers using DDU? Ill back to you later as I'm due to leave to work.
Edit
Your memory usage is also high as 90%?
I have a pc of 4 years, lately when I'm gaming I'm having 'fps' issues.
What I mean by this is when I first load a game up its fine then maybe 30 mins or so in its like I'm playing on 20 fps it's juttery and so bad that I can't play. The weird thing is on the fps counters in games it still says well over 150 when in this jittery stage.
Im so confused at what it could be and any help would be appriciate!
I have a Amd raedon 380 2gb.
The games I play are csgo and fortnite
Before loading a game up: https://gyazo.com/0c303210f0f42df25eb4a19c6da0bb46 https://gyazo.com/874917abc5b165ea209271f7554865bd
Mid game stuttering: https://gyazo.com/9dab59b32e67ed5e37a5a8c4774c3caf https://gyazo.com/4ffc3d5c70e9467bc108edc0082dc26a
I have 550W Power Supply not sure the make could check if need to once im back?
Edit
It would be helpful if you took the first screenshot again to include the same sensors from the second screenshot so we could actually compare the perameters. I'm still dubious about those temp readings, they may just be erroneous but without the first screenshot to compare them too who knows.
This is your issue OP...
I had this issue before when I has 1 stick of 8Gb running in Single Channel playing PUBG...massive lags all of a sudden.
Are you running 2x4Gb or 1x8Gb?
If 1x8Gb you need to upgrade or reduce the amount of apps running in the background (look at Tasks/Processes under TaskMgr and try to disable non-essential ones in there).
If 2x4Gb, firstly check you're running the RAM in Dual Channel and not Single Channel.
That high amount of RAM with definitely cause the stuttering you are experiencing.
Time for a RAM upgrade, or to try playing the same games at a lower resolution or or lower Texture Level/Detail
Can you, OP, try the same game but at 720p Resolution with Medium preset? See if you still get the issue?
Ah so you think its a RAM issue? i have 2x4GB sticks atm my motherboard only allows 2 sticks. My brother has just built a new PC with 2x8GB sticks would i be able to try them in my pc and see if it still occurs?
Also i play most games on Low/Medium settings, however at 1920x1080, but ive never had a problem till the past month or so.
Is the game using more than the 2Gb of video memory?
If he builds a new pc now it is ddr4 and your motherboard needs ddr3 so if that is the case it wont fit. When you're playing do you have any internet tabs opened or other programs? I only got another 8gb of ram as AAA titles started using it but 8gb should be plenty for cs go and most of the other games. When I played cs go it was completely fine with 8gb of ram. It is worrying that you have 90% usage as it can cause issues of stutters you are experiencing as @JCLDJB stated.
Also as I mentioned above you may have a memory leaked caused by bad driver i.e. in the past when I had z87 mobo it had an ethernet driver causing the leak. Of course, if you don't have anything opened other than the game. Further does your computer crash after x hours, similar to when in games or is it fine?
I would lunch task manager and see what you got opened and if ram fills up without a reason which would indicate a leak. Usually, with leaks, it will eat 1-3mb every few seconds.
Driver Crashing can occur due to lack of VRAM or bad/damaged drivers or hardware itself. You can try to uninstall them with Display Driver Uninstaller from guru and installing the latest. I'm unsure if this will solve the problem as your RAM usage is in high 80s/ low 90s%. I cannot imagine 90% usage for cs go when only running the game so this can be a memory leak or software you got installed on your pc or applications running
You never had a problem until now cuz as time goes on..you install more and more things on ur pc.
Try this: press the windows key on your keyboard then immediately type [MSCONFIG].
Locate the Boot and Services or Startup TABS.
Then disable any app you don't use regularly (and by regularly, I mean daily).
This will disable a lot of clutter at startup and could free up a lot of RAM.
Then when you are playing a game, make sure you always have at least 10-20% free.
See if it helps with the stutters.
Could i just buy a new GPU to sort the problem or do you think its more than that?, i was on CSGO a little earlier and my GPU VRAM usage kept shifting from like 15% to 90%+ i didnt play it long enough so the stutter occured which is what im going to try next then record the findings, once im home.
Already disabled the majority of things all i have on start up are: Realtek, Steam, AVG, Java, Dropbox, Catalyst Control Centre, Intel USB 3.0 Monitor and Steam rest of my programs are disabled.
I completely missed out the gpu vram usage, but stutter wont occur until 100% ussage in most games. You can test the gpu in your brothers pc if you like. My sister recently got a 750ti 1gb and i played cs go on it with vram usage mid 90s and it didnt stutter after 2 competative matches at all. (She has i7 4790, 8gb ram). What i found generally as you fill up normal computer ram above 85% computer begins to slow down as system paging starts occuring when near the limit.
Few questions
Could you take a screenshot of task manager
sorted by amount of ram used when stuters occur and when pc runs for few minutes??
Did you reinstall the drivers using ddu??
If it helps i can skype with you to guide etc if needed.
UPDATE
Also device manager updates wont get you the latest drivers. Your best bet is manufacturer motherboard website
OP, You can go round in circles all day or you can try doing what I have already suggested to figure out where the issue lies. Download MSI afterburner, close ALL applications including web browser and launch Afterburner only. On the graph add anything that you can to monitor including anything that monitors temperatures, clock speeds, usages etc for both the GPU and CPU as well as RAM usage. Let it log for 15 mins and then make a note of everything. Once that's done launch the game you are having issues with leaving afterburner running in the background, minimised if need be. Now play the game until the problem occurs then keep playing for another 2 minutes. After that close the game and look at the graphs on afterburner, look for anything that changed when the problem occured. The extra two minutes is to make it easier to spot what exactly changed, if your fps dropped look to see if your RAM usage maxed out, or if the clock speed of the GPU OR CPU dropped. If one of your clock speeds dropped then look at the temperatures at the moment it dropped and make a note of them. Their are so many things that it could be, we could make guesses all day. The best way is to rule out Hardware first then move onto Software issues.
Few questions
UPDATE
