Hi All,
Hi all, i have a new gaming laptop & I'm trying to work out why my GPU doesn't run at 100% on the graphics tests in 3dmark...
The laptop is new - link below to the exact make/model and specs:
https://www.overclockers.co.uk/medi...-intel-i7-10750h-gaming-laptop-lt-00v-md.html
Specs also below:
Intel Core i7-10750H
32MB DDR4 2666mhz running in dual-channel (I upgraded this because stock comes with only 1 x 16mb stick in single channel)
Nvidia RTX2070 Super mobile (NOT the max-q version)
Windows 10 home + latest updates
Latest geforce drivers (excluding geforce experience)
Below are a couple of graphs of what seems to be happening - as you can see, GPU load rarely goes above about 95%, when running Firestrike, and my (stock) graphics score of around 20,500 does seem to be a bit lower than the average for systems with identical cpu/gpu combo...
Temps are also good, at max around 72 degrees on GPU and 80-82 on CPU
Something's holding me back, and i'm not sure what! ANy suggestions would be gratefully received!
Many thanks
Specs also below:
Many thanks
