Graphics card problem...too much?
8 Jan 2007
my graphics card seems to have be having a weird problem. when i run pcmark05, after about 2 minutes, the ati control center will pop up saying it had to reset the graphics card or something because it wasnt responding to drivers anymore
i have never had these problems before, granted the computer is only about a month old, its only just started happening recently
im thinking maybe im pumping too much voltage to the card and its had some pretty negative effects on it?
these are my bios settings, is it too much? or does the problem lie elsewhere?
its using a multiplier of 9, ram timings 4-4-4-12
Also is it OC'd? I was getting similar issues on a faulty g card but my problems were only ever in game! The card was getting far too hot I think.
its not overclocked, not yet anyway
and it happens in 3dmark too. it doesnt happen all the time, but when it does, it stops the tests and pops up a window saying its not responding to control drivers anymore
the worst thing about it is it happens at random times so i cant tell what the problem is
Have you tried installing different drivers for your card it could be something to do with compatibility or corrupt drivers. What card is it by the way? I would use driver cleaner too if you are going to try different drivers
There are many issues related to the HW acceleration of the X1950XT cards.
I've been having such a torrid time with mine, so much so that I've given up and ordered a 8800GTS.
Mine ranged from MC crashes to BSOD during 3dmark05\06, etc.
well the drivers have never been a problem until recently
im thinking it may be something to do with ram timings. is it possible that lowering the ram timing could cause a problem like this?
There's no need to have your SB and ICH overvolted. Leave them at auto or lowest values and see what happens.
The PCI express slot is connected to the SB (Southbridge). Thats a possible culprit.
well ive lowered the SB and ICH voltages, even lowered the FSB, still gives me the error randomly
could it have anything to do with ATI tool? im using that to control the fan and clock speed, so if the video card is listening to that, then is it possible that its not responding to the drivers?
