- 20 Apr 2013
- London
mmm... white and blue themed build?
How would these compare to the Fans that come with the Antec 100, or that came with the OCUK special AIO H2FLO kits a few years back.
I have a few fans starting to reach the end of thier life and am wondering about a wholesale replacement of the lot.
Ok I bought 3. These will be used for 1 on my H90 and 2 on my 295X2. I hope they're good!
Just paniced a bit as I have no idea how to remove the fan from the 295X2 is it easy with no dis-assembly?
A the radiator fans? They're just the same as replacing other fans, but you'll need to align the radiator up and make sure not to drop the rad while removing it.
If you mean the one on the card itself, that's not removable/changeable.
Not the card one the radiator one that is on a long wire to the card. I worry it isn't removable without tools?
But neither is an 1850 GT.
...'rjkoneill designed SST-FQ121WC' ....
Sounds good, I need 4 more fans.....
If the price & performance sound good i'm in![]()
Most of us seem to consider the Piranha to be a pretty good rad/heastink fan and it operates at the same kind of RPM range as the GT1850/SST-FQ121.
Might as well bung it in the test to clear up the situation![]()
I am aiming to get it sub £10 per fan.
when they turn up. yes
my testing was detailed here.http://forums.overclockers.co.uk/showpost.php?p=26882708&postcou.=18
the akasa piranha isnt a SP optimised fan?
Neither are 800rpm eLoops. No fans are.
