Hi Guys
So Silverstone have come back to me this morning with pricing quotes for my new 'rjkoneill designed SST-FQ121WC'
this fan is being built to my exact spec
Silverstone have been working around the clock to get this built for me.
I should have my samples early next month.
the fan will probably be a little more expensive than the standard FQ121 as they are being made in much smaller quantities, but will have the added advantage of a better spec.
I wont give too much away but it is essentially the following:
- SST-FQ121 Frame and Blade design
- No sticker on the front of the fan.
- Colour Black Blades / Black Frame
- Same Bearing as SST-FQ121
- No PWM
- 3 Pin Connector in black.
The lack of PWM means it is ideal for watercooling enthusiasts looking to run their system on a fan control unit. This will be perfect for users running low FPI radiators and Smart controllers like the Aquaero as the noise level and speed will be able to be tuned.
Given the performance I have seen from the standard FQ121 run in 3 pin
This is exactly what I want. Will look out for these next month.
