You say the cables will be black. Will they be braided or just black ribbon/twist style?
Also when they become the OcUK special. Will they replace the white/blue on the tech labs bundles? (the SR1 for example)
Any news on the ETA or pre-order offer you we're discussing previously?
Hey Rjk, if these are successfully do you envision getting others custom made? a GT1850 equivalent is a bit too much for me but I would happily snap up a couple dozen GT1450 equivalents.
Can these be controlled with a 3pin normal fan controller?
edit:Will see just ordered 5 for my rads
running them at 10v would do that.
Yeah but there's a limit to how much you can lower them, in my experience the GT1450's could run at sub 800RPM but the 1850's would stop spinning before then, hence why the GT's had multiple versions.
It's no biggie I'll just grab some of these for performance builds and use something else for quiet builds![]()
I run (9) 1850 GTs anywhere between 400 and 1200rpm under most situations generally sitting ~650rpm happily and silent
Cool they must have revised them over the years, if these can do the same then I'll buy a boatload![]()
