Not sure i understand bottlenecking completely in BF3 so can some please tell me how mine looks.
3770k @ 4.4 = 60% use
680 sli @ 1200/1600 = 99% use on both cards
310.70 drivers.
Thankyouplease![]()
*cut*
I can't grasp how I can't get my GPU's at 99%. Maybe it is triple screen gaming and the bus of the 680's isn't man enough to let the GPU's get to 99% or maybe something is wrong in my computer.
I have no idea and even putting my CPU at 5Ghz still doesn't let my GPU's hit 99%. iirc, 90% is the most I have seen them get to but other games are different and I have no problem getting 99% on both GPU's.
I gave up in the end, as it was playable enough and I couldn't find an answer.
Have you tried just running with one monitor to see if you get better gpu usage?
No Tones. I am talking 5760*1080 res...I am struggling to get a constant 60fps at that res let alone 200![]()
Sorry Gregster i just noticed your on 2 cards?? i have no problem with that with the same board+cpu as you im only at 4.4Ghz most the time and its 95/99% usage all the time on 2 cards :s
I noticed something similar on 306.97 (just before I swapped). Usage had started to mess up from a locked 99%/99% to jumping around.
I clean installed drivers and rolled back to 306.23 and it was 99% for a couple of maps then, again, it was all over the place. This was in BF3 MP.
I surmised it was a combination of me not using maximum settings (as being in Surround with only 2 GPUs); the game engine perhaps changing; driver optimisations slipping....![]()
Did you try any older drivers :s
I wanted top scores in 3DMark11 and so tried them all to see which gave the best results.
I just checked usage in operation swordbreaker and it was saying 85% in AB but when I checked with GPU-Z, it said 99%.@gregster
Remember, we did a test a while back on a similar theme,
I'm sure you was getting 99% on both but then it dropped off to 80-85%
when we went to a single screen
edit - it was when we proving i7's(hyperthreading) benefits BF3
