GPU-Z doesn't always give an accurate readout, it certainly isn't with mine, it may have something to do with the fact that mine is supposed to run at 1253Mhz out of the box but actually runs at 1354Mhz.
Strange happenings with GPU Boost 2.
Our gcards are similar mine should run 1354, but runs 1418 out the box.
yea I get them up but when I take a screen shot there not there.
tried that... still no joy for me? try on screen display tab, tick show on screen display on captured screen shots and videos?
Looking at your screenprints, I don't think you are hitting 1600mhz or 1590mhz but its 1441-1450,. It would explain why you aren't getting around 13600-13800 on the graphics score in firestrike.
yea as stated I was going with the speed said in the top right hand corner of valley. but then I saw youre screen shot and I added my core and memory speed to my OSD and I saw Msi a,b was reporting it lower.
Keep the memory stock and find your core first, if you're getting near your thermal limit the clock will drop down a bin 13mhz.
