Heaven, Valley the OSD you can see is built in the tool and not the Precision OSD. Do you not see the OSD in any application beside of the benchmark ones? Have you already tried a later version of Precision?
Problem with the stock bios is the power limit would screw around with the voltage, and clocks would jump around as result. Voltage could go from 1.21v down to 1.81v, and clocks would drop 30-40mhz. My custom bios moves the power limit to 425w and keeps the voltage locked at 1.23v in 3d apps. Clocks stay locked unless I hit somewhere around 82C, then they drop 10mhz.
Played around with 1.255v, hit 1515mhz with an hour of heaven. Still waiting on the block before using any more voltage because of temps.
Getting my new fans tomorrow. Just out of curiosity guest. Is firestrike accessed through 3d mark on Steam? I would like to compare my score with yours before and after overclocking. Also when you say set to aggressive? I dont see that all I see is a chart type system, where you draw a line.
Hi, as it turned out I received a new 980ti classified which clocks fine to 1500/4000 at 1.21v. I have yet to see it throttle, even when it reaches 70c. The previous one would throttlw at 66c regardless.
I didnt end up using a custom bios or creating my own but may still try it.
You would enable it by using the maxwell bios tweaker and customising the bios, yep, bios change would work with any card
