Caporegime
Wow, 7970 with 60% more shaders, 50% higher memory bandwidth and ~65% price premium, running at same speeds, and the poor little 7870 is only 23.5% slower within the most shader intensive benchmark available. Bar-humbug.
My £149 7870 @ 1325MHz/1500 (24/7 clocks) is only 20.3% slower than that. I can run a balls out bench at 1355MHz/1550MHz but this is very far from stable. But I am sure at much higher resolutions the 7970 would pull away.
7870 even when overclocked still struggles with dips to high 30's on Ultra in BF3 with 4xMSAA though. Guild Wars 2 doesn't run great on my 7870 either, infact parts of it ran smoother on my 6950. I really think there's still more to come from future drivers.
What settings on Guild Wars 2 mate?
If you drop reflections and shadows down it should be a lot smoother... I find they drop FPS the most for me.
That's a great ASIC. If you are lucky, 1300MHz+ should be possible at 1.3v. I suggest you download and install Afterburner, set volts to 1.275v and try 1250MHz to begin with. If that fails, lower MHz or increase voltage.Hi
So I got my B grade Gigabyte 7870 .. installed all fine, no problems.
Installed 12.8 drivers and gpu-z. ASIC of 88.3
Ran Heaven benchmark at stock speeds/voltages with result of 1425.
So what now... do I need afterburner to start playing ? Should I jump straight to 1200/1300 ?
please tell me if this is off topic and I should start a new thread
Thanks
When did you order yours?
I just got an email from them saying they have no stock and that it was a system error that I was able to order it. Quite annoying to be honest
