Sultan of Ping said:Great guide, and a fantastic, clean result too. May I ask how long it took you to make the main cuts on the panel with your Dremel?
I ask this because I have done a similar mod on my Coolermaster stacker, but with AquaComputer 1x160 (2x80mm) and 1x120 rads/grills. But I used a cheapo Focus dremel-copy and it took me almost 4 hours and loads of cutting discs, no word of a lie!! Are original Dremels worth the extra outlay?
kinggost said:Does that he120.3 grill work for a pa120.3 as wel
gr1mey said:the grill isnt attached directly tothe rad, by using the piece of angle aluminium he has as an adapter, any rad could be made to fit to the AC grill.
afaik though the HE and PA rads both use the same holelayout (well all the ones Ive seen have).
Aquatube is too expensive for the acrylic version, wouldn't consider an aluminium one. Aquabox is very similar to the other Re-pack delrin res I have already.looks very nice, You could put an Aqua pc res in front of it
paulc said:Noticed in the final pic you've modded the front and back for 120mm fans. More dremel magic? Probably going to try the same, although the stock fans aren't too bad, but quieter is better.
