Hi, I know nothing about VR and am looking for two bits of advice - Is my spec below OK and what VR device should I be going for?
1 x 24GB ASUS NVIDIA GeForce Ampere RTX 3090 (1 x HDMI | 3 x DP) - RTX Enabled!
1 x ASUS ROG STRIX B550-E GAMING DDR4 ATX MOTHERBOARD - AURA SYNC RGB READY! [WiFi Included]
1 x 1000W - ASUS ROG Strix Fully Modular 80+ Gold PSU
1 x AMD Ryzen 9 3900X 12 Core CPU with Wraith Prism RGB Cooler [GPU Required]
1 x GameMax Iceberg RGB Watercooler - 240mm
1 x Corsair Black iCue 4000X RGB Mid Tower Windowed PC Case
1 x 32GB (2x16GB) Corsair Vengeance LPX DDR4 3000MHz - Black
1 x RGB Kit (3x12cm Fans + LED Strip)
1 x Arctic Silver 5 Thermal Compound
1 x 2TB Seagate Barracuda SATA III 3.5" Hard Drive 6GB/s
1 x 512GB M.2 PCI-E NVMe Solid State Drive [Up to 3500MB/s Read | Up to 2300MB/s Write]
1 x Windows 10 Home 64 bit Operating System
1 x ASUS PCE-AC88 AC3100 2167Mbps 802.11 a/b/g/n/ac
Thanks in advance
What do you have? I’d be looking to sign up to the FE drop alert list on Telegram and Discord and aiming for a 3070 or 3080 FE. However a 3060ti or higher end 20x0 or Super variants will also be suitable.Now the happy owner of an i12700k based system. I'd like to try Halflife:Alyx on my Quest 2, what are the graphics card options that would leave me with both kidneys ???
2070 Super or try and nab a 3060ti FE from a drop then.Currently an old AMD R9 200 series
The main use for the PC these days is Photoshop so not looking for an uber gaming rig ( it's been a few years since I spent the night playing CS:Source)
unfortunately PCVR requires a higher end gaming pc than a flat screen game so if you have a pcvr capable device you will by proxy end up with a fairly capable general gaming pc rig. I agree with what mischief said btw 3060ti or above or last gen equivalent. a 1080ti would also do a jobCurrently an old AMD R9 200 series
Is the spec in my sig, enough to play around with the Quest VR system?
I can't see sigs on my phone
I've got a amd 3600 with a 5700xt , 16gb ram
No problems
I've a 5900x and a 5700XT, 32GIG of 3600 RAM
