Permabanned
- 8 Mar 2003
- Looking at the internet
Has anyone used a Guitar Bug before? They look very good on paper for under 100 quid, but are they any good?
cheers
cheers
jonorigin said:I've got one and it's great. Just works, simple as that! It's great to not be stepping over wires all the time as well!
riddlermarc said:There's a thread here discussing wireless transmitters if that's any help?
jonorigin said:I haven't noticed a drop in quality at all, and the freedom it gives you on (and off!) stage is great!
jonorigin said:I bought some of those sellotape velcro pads they seemed to do the trick fine. 3 of us in the band have wireless kits and we are all very happy with them indeed, horses for courses I guess!
jonorigin said:haha, you'd probably hate my setup then! These days I just use a pod xt live straight into the PA (when it's beefy enough anyway)! Best sound i've ever had though! Nice and easy for the soundman, but some guitarists look at my setup like i've comitted blasphemy!!
dmpoole said:Even my £450 microphone is not what it should be but needs must.
