h100i Link , pump speed.
2 Mar 2014
Janitor closet
Got my delivery this weekend , it all went together suspiciously well , its been running since Saturday night ..not 24/7 but a fair bit ... ran PC mark on it to try and work the CPU a bit and nothing above 45 degrees (ish) ... can i presume the mounting of the heatsink was a success , and it look like its working with as intended ?
I am pretty sure it is ...just looking for some backup :D
*The GTX 260 is my old card .. a stand in for now , to be fair, the onboard was doing a great job ..played a bit of the BF3 campaign with very playable fps
Cant tell much from idle temps but looks fine. Staying below 45 is what i would expect from a stock 4770k with a upper end air cooler, so looks spot on.
It'd be a shame not to up the clocks now you got the cooling!
Ok cool :cool: ... the pump will just do its own thing then ..i don't have to regulate the speed anywhere ?
Agreed about the OC , i have no excuses as the MB has an OC genie button ,
wanted to make sure it was stable before i do anything to it .
As far as i know, the link software does that for you. Dont use the OC button, find a guide and follow it, you will get better temps and a higher overclock. Auto overclocks use more voltage than needed and are incredibly mild clocks.
Nice ... cheers dude
