H50-1 problem
17 Nov 2010
UK
would like to get one of these watercoolers along with a C2Q, but my case only has 80mm fan fittings
is there any way around this?
thanks
a) Get a new case.
b) Make the hole bigger
c) Make a new hole.
d) Don't get a H50 cooler.
e) Things I haven't though of.
Buying a new case would be the easiest option, you will need to make sure there is a 120mm fan on the back of the case. I would recommend using Akasa Viper fans too for the cooling as they tend to be quieter and more efficient.
