I've run out of hair gel and decided to use wax instead but I have no idea which one to use. Whoever uses wax can you give me some reccomendations please.
theres different types? just get a load on ** palm and rub your hands to gather and warm up the wax. this will make it easy to spread the wax through ** hair.
then just style it..
Fish Hair Putty (maybe called fiber putty) is really good, Boots usally sells it. Black-n-White wax is good as is Dax Wax (be careful as some daz wax is near impossible to get out of your hair!)
Yeah i use a wax stick. Just roll it all around your hair, a bit of preening and you're good to go. Easy peasy. None of this standing in front of the mirror messing about with water and gel for half an hour! (Silly housemates )
They do a range of other waxes as well so you may want to check them out. You'll have to go into a barber's for this as I dont think Boots etc. will sell it.
