Half Life 2 RTX
Makes me laugh people saying this is unplayable. As evidenced, it's perfectly playable on a variety of hardware at the appropriate settings that your GPU is capable of... It's almost like people don't realise you can adjust the settings. And incredibly there are still people who refuse to use upscaling even with the latest transformer model :o
Nah mate grainy and totally unplayable:
This is with double the light bounces of ultra and DLSS set to quality, forgot to close something in the background as well when recording which slightly dropped my FPS by 1-2% as well. Getting my excuses in but I'm pretty rusty as well.
Looks like it's the undervolt/oc that causes the crashing, weirdly played all of Raven earlier and no crash, but 3 mins into nova and crash. Turned off UV/OC and only did 80% power limit and zero crashes, fans a bit louder than before which is expected but otherwise all good, framerate appears to remain similar so will just leave it like this. First game to not like UV/OC!
Now half way through Nova and stuck in a bit after the gates are opened and there's a sentry in the corner behind a table. Only got 18% health so think I'll have to redo Nova and retain more health :p
:Look how excellent it looks:
Butter smooth too and zero stutters or frame time issues. Roll on the full release soon.
Grainy, crappy, not worth even trying.
I thought that it would look good and run smoothly but its waste of time. No point releasing something like that when there is no power to run it.
Power that you have, you mean, it's not the devs fault if your hardware is underpowered? Did you also moan when Crysis came out and nobody could run it etc?
No, i did not moan on Crysis, I played it smoothly :p
There will always be people butt hurt when they can't run the latest thing...
Plays really nicely here.
DLSS Balanced - 80-90fps or 140-160fps if I turn on frame gen
RTX HDR makes it look even better but didn't work straight away. I needed to reboot the game after enabling it
No crashes and a max of 420w - 66c so the undervolt is holding strong here :)
You can use DLSS Performance if on a 4K output, it's as visually good as Quality of old since we are now on DLSS 4, there's no real need to use DLSS Quality or Balanced any more when outputting 4K. 1440p a different story of course.
Installed driver and launched the demo, PC then crashed lol
Can't tell if its a bad driver or issue with the game, cause the demo doesn't run with any other driver
Nah sorry but look at all that grain, it must also be a slideshow....
:cry: :D
In all seriousness, are the ones saying it looks grainy by any chance using amd gpus? Could be that the denoising tech in this is not working for amd hardware. Wouldn't be the first time a rtx remix title has exhibited graphical issues on amd gpus...
Only RTX cards can use Ray Reconstruction and the Neural Rendering Cache so that could explain any complaints about "grain" or "noise" I guess. Also not being on DLSS4 will make a visual impact for the worse .
Yeah I'm still blown away with how good dlss performance with Transformer model looks in KCD2. Changing it to balanced or quality is just pointless, at least to my eyes. Everything looks so sharp and clear. I accidentally used the old model after the patch and could immediately see the downgrade, dlss4 is fantastic.
  • Like
Reactions: TNA
Yup that's what I thought! Can't believe amd haven't got a competing tech to Nvidias ray reconstruction yet.
Only a demo atm and it’s still causing some people to mald out. Claiming it’s just a marketing tool and it should run the same as the Crysis 3 RT remaster :cry:
On the plus side, by the time the whole thing is done in the usual 'community mod' 5 year (at best) timescale, the hardware to run it will be cheap as chips :p
I enjoyed it last night. Looking forward to the full game. Been wanting to replay HL2 so this will be perfect.
I have HL2 and the HL2 RTX is on my wishlist but when I clicked on Add to Library, nothing happenned. I had to go into the Store and add it manually.
