- 18 Oct 2002
- Xbox Live
As a team ultimately you want to control as many of the power weapons as possible so that the enemy can not use them against you. To do that you need to balance out what you have (usually the BR is the other weapon, however the combos I mentioned above are good "power weapons combos"
The BR's strength is that it makes you dangerous at most ranges (but mid range is its best range) but its down fall is that its not a 1 hit kill weapon, it needs co-ordinated/sustained fire or the enemy needs to be damaged before being killed. The BR user will loose to any 1 shot kill weapon (fired form the right range on target)
I agree however you want to have a BR 90% of the time.
