- 18 Oct 2002
- Kuala Lumpur, Malaysia
We have a PC which restarted on Friday then wouldn't boot into windows and said something along the lines of "disk read error" , after turning PC off and disconnecting / reconnecting the drive I managed to get into windows
The drive is a 150GB WD Raptor - downloaded the WD diagnostics utility which found no errors and did a full scan using HDtune, and also no errors
Event log shows a fair few of these errors :
So to me looks like there is definetely an issue with the HD - is there any other diagnostics I can run?
What's the best software to use to make a complete image so I can restore fully on a new disk? As the drive is working at present and would prefer not having to install everything again!
And a previous crash a bit before had this code :An error was detected on device \Device\Harddisk0\D during a paging operation.
The device, \Device\Harddisk0\D, has a bad block
The system failed to flush data to the transaction log. Corruption may occur.
A parity error was detected on \Device\Ide\IdePort2.
The driver detected a controller error on \Device\Harddisk0\D
Error code 10000050, parameter1 e4f6d0ac, parameter2 00000000, parameter3 bf8b6188, parameter4 00000001.
