Is there anything available which would let me mount a SATA HD in the front of my case, i.e. where the CD bays are and which would internally connect to the SATA ports?
Basically, I'd like to be able to remove the drive easily if I ever want to take large files with me. An external enclosure is a solution but as it would be connected to my computer 99% of the time I may as well take advantage of the full speed - my motherboard (Asus A8N-E) doesn't support eSata as far as I know.
Failing that I guess I could just hang wires out the front
Thanks
.Thanks
