Hard drive may be acting up, what disk checking program?
7 Dec 2009
Hi all
I think I might be having a problem with one of my mechanical hard drives, everything is backed up but what is the best program to use to check the health of the drive.
I have seen a few but they all seem to be for specific purposes, is there a general diagnostic program that will check to see if everything is working as intended?
Thanks
Kel
Look in Windows Event Viewer.
Check the System tab.
-edit, quoted an old post I made.
Memtest
Eventviewer to check for hard drive errors
The way to use event viewer..(Windows Vista/7)
Windows logs
>System
Click Filter current log.
Select 'Event Sources', then click 'disk, Disk', click OK
It will have every problem ever recorded for hard drives
