Hard Drive messed up?
  • Thread starter Thread starter A2Z
  • Start date Start date
A2Z
A2Z
Permabanned
9 May 2005
Earth
Maxtor 250gb sata about 18 months old.
I am continually getting all sorts of errors.
IE/FF/MSN/WMP will randomly get a 'has got a problem and needs to close' error message thing, very frequently
random BSOD causing restarts
when trying to play cs online, getting 'bad files' or 'file missing' when connecting to servers
This is all AFTER a clean re-install of windows
also...
when i was reinstalling windows, i tried to install it on my normal windows partition, but it FAILED when formatting, so i had to install on another partition which i didnt bother formatting first.
do i need a new HD or is it something else?
and what can i use to check if the HD is ok or not?
Craig321 said:
Are there any errors in the event viewer that point to your hard drive?
Start>Run>eventvwr>system
there are about 80 errors there from the last 4 days or so when i resintalled windows, and about 50 'warnings' how do i know which point to my HD?
under 'source' the errors range from:
Dhcp, System Error, Service Controle Manager, ntfs,browser,sr,DCOM,setup
hmm there are 2 ntfs ones, which both say:
The file system structure on the disk is corrupt and unusable. Please run the chkdsk utility on the volume C:
Craig321 said:
You could try giving it a low level format with PowerMax. THat might helps things?
i looked at that powermax thing but seems you need to create a floppy disk?
i havnt had a floppy drive in my pc since i built it 18 months ago :p
With the powermax auto creator thing you need a floppy, but you can probably use a usb stick as well.
