Hard Drive not recognized
14 Nov 2010
SO i just built my computer. IM using a SSD and a 500G samsung Hardrive. In the BIOS it shows both but the OS only shows the SSD do i have to format the regular hard drive to make it show in the OS
Right click Computer in the start menu then choose Disk Management. You should be prompted to initialise and format the 500 ;)
Be careful about formating the HDD.
If you had it connected when you installed Windows onto the SSD some files may have been installed to the HDD and Windows will be broken if you format.
The HDD should have been disconnected when you installed to the SSD.
Ya t wasnt plugged in during installing windows. Kinda by accident but sounds like it worked out perfect. I got it formatted works perfect now thanks guys
If the drive wasn't initialised there's no chance any files from the Windows install process would be on it. Agree any installs should be done with only the boot disk plugged in, just good practice
well now i know that for the future.
It all worked out perfect for me thanks
