Hard-Drive not registering...
29 Nov 2002
Midlands. UK
My PC recent went screwy and i had to replace my mobo that had borked. So i installed my new mobo (Gigabyte GA-M56S-S3) and installed windows fresh on my SATA drive.
So all working.. I installed my 2nd hard-drive an IDE Maxtor 320gb.. But when i look in windows it shows it as having 1 partition (not-formatted) and 1 half un-partitioned (un-allocated). But prior to me changing hard-drive this HDD was working correctly and had 2 formatted partitions with all my files on it..
Any idea what could be happening?
Administrative Tools> Computer Management> Disk Management
Is it a dynamic or basic disk?
Maybe you need to initialize the disk?
Last HD I bought I selected not to go with the default option disk management gave me and it turned into a dynamic disk.
This sounds familiar to the problem I encountered:
http://forums.overclockers.co.uk/showthread.php?t=17738207
It might be you need to convert the dynamic disk to basic. I used the "hack" method but I have seen microsoft offer a method too.
The microsoft method asks you to eraze each "volume" which erazes data on it:
http://support.microsoft.com/kb/309044
so you might be better to use the "hack" method.
That is if this is the same situation.
