Hard drive problem
5 Jun 2011
London
Hello,
I'm running windows home server 2011 and one of my 2tb HDD's is playing up. Connected by Sata, windows can't see it (in my computer, drive manager or device manager).
But when it's connected through a usb caddy it's fine!
Any ideas what the problem may be?
Thanks
Coops1992
5 Nov 2014
are you able to try a different sata cable, power cable or sata port at all?
does anything appear in disk manager?
OP
5 Jun 2011
London
Tried 2 cables. And 2 ports. One on a PCI-e Sata card and one on the MB. The only cable I haven't swapped is power. It's a Y-cable for power and he other drive works fine so doubt that's the fault?
No nothing atall comes up in disk manager.
I think I last used it as a dynamic disk as raid1/mirror. But when connected by usb. It comes up as a basic disk and its formatted in ntfs
OP
5 Jun 2011
London
Great. I'll give it a try. The drive is blank. Just formatted to be a mirror.
Is that raid function in all bios'? It's not a raid card just an adapter I think
