Hard drive trouble
24 Jun 2006
i have reciently replaced my mobo and set my sytem up how it was but i forgot to plug my second hard drive (maxtor 80gig) back in. once i relised this i shut down windows and plugged it in and restarted the pc. now i get an error saying error loading operatign system.
the hard drive doesnt have a os on it it only has a few files i use it to drop files on when my main harddrive is getting full
i have tried booting windows and plugging the hd in but like i suspected nothing happened.
i have even tried repairing windows but still get the error, i though it would have rewrite the window files on the maxtor hard drive but it didnt.
i have even done a full format on my normal drive to see if that would help (normal drive needed a format any way so i didnt was any time doing it)
has any one got any suggestions as to what i can do apart from formating the drive. i kind of wanted to get the files of the hardrive before it came to that
The BIOS is setting the 80Gb drive above your OS drive in the boot priority list. Change that about and everything will work fine.
