Hi all,
I have purchased these components for a new PC,
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retai
l
MSI 870A-G54 AMD 870 (Socket AM3) DDR3 Motherboard
Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel
I put it all together with a new PSU which works ok, I have complete failure,
i.e, CPU fan starts, no beeps at all, no video, nothing....
The Mobo overclocking led is on and the onboard switch will not turn it off.
I notice that the Mobo does not have the OC jumper switch fitted ????
I have also put the mobo and cpu on the table as a bare bones setup, mobo and cpu only and it's the same.
My question is, what component is likely faulty, CPU or Mobo.
I am NOT happy about the charge for testing which ever part is not faulty, this I think is dishonest as how am I supposed to know.
I read on the web that this is a common occurence and is usually a faulty Mobo. It seems I have wasted quite a load of money.
I would very much welcome your comments please.
EDIT..
I just checked the BIOS chip, it is... 7599AMSHD0... THE msi site says it should be 7599AMS.H40
How do I change the BIOS when the Mother board clearly does not support the CPU and it won't start.
The Overclockers web page also states this...- Support for 64bit AMD Phenom II and Athlon II CPU
Thanks Monty...
l
EDIT..
Thanks Monty...
