The switches often go to a main CANBUS controller anyway so its the same problem
Yeah but if a single switch fails the rest of your controls aren’t impacted. If your central display fails, you can’t do a thing.
VW MEB have the speedo and HUD separate to the infotainment. Are you not just thinking of Telsa model 3 when you say no speedo with no infotainmentBecause cost cutting. It's much cheaper to have everything software controlled from a central panel, but it's never the best way.
But it also means there is no redundancy at all and if it breaks, everything breaks. It's like having all your data saved on one laptop with no backup. It should be banned for any basic car controls or functions. If you have a digital dash/hud and the infotainment unit dies, you'll lose the speedometer which means the car is no longer roadworthy due to the ******* radio not working.
Show me a touchscreen that fails frequently. Even the 2006 XKs are just fine
I still await the answer. Which EV have you driven?You two are like Mr Burns and Smither. Not figured out which is which yet.
Or the same person with two accounts.
Every thread lol
I get what @Nasher means though in that having everything on one or two displays is a problem waiting to happen, as an example on my old 308 I had a glitch where the dash and infotainment unit went kaput on one journey and I had no idea what speed I was doing so I had to pull over to the hard shoulder and wait for it to fix itself.VW MEB have the speedo and HUD separate to the infotainment. Are you not just thinking of Telsa model 3 when you say no speedo with no infotainment
True but it's been a while since I have seen a car with an engine go pop whereas with newer cars I find that the components around the engine seem to be more susceptible to problems.Old cars are rubbish too as if the engine breaks the car is equally useless ??
Weirdly my born drives fine even with the screen turned off. I have a Speedo too. Let’s not listen to nasher about EV. Seems the closest he has to experience is by sitting in a passenger seat of a Tesla
Name anything in life that has gone up in quality. Cost is the focus. To be honest though it’s a bit of an assumption to link that scratch to quality. That could have been anything you hit that would have marked any wheel regardless of age.I'll preface this by saying I haven't owned many cars but recently I've felt as though a lot of the new cars on the market have really sub-standard quality/finishing.
I remember when my mum and dad bought cars in the past and you could walk down the side of them with your coat on, stand on the sills, drive them without worry and they'd get a few marks here or there but they could always be polished out without anyone being able to see them
Now though it seems that you so much as look at the paint work or the wheels funny and it gets a mark deep enough into the clear coat to warrant a respray.
Even when it's not damage related the quality of the paint work that's turfed out just feels sub-par from the paintwork being contaminated to in some cases just flat out not having enough on and being able to see through to the basecoat.
The past two cars I've owned have been relatively new and have either had really soft and delicate paintwork or the wheels on them have barely been able to cope with standard usage without suffering damage.
Part of the reason for this post is that this morning I just found a scratch/chip on my wheel on a car which is less than 2 years old and that has done less than 3000 miles on the left side (So it's not even facing oncoming traffic at the best of times)
/rant
Is it just me or does anyone else think the same or have similar stories of newer cars having suboptimal quality?
One. Or two? The issue was one display only in a car. Most have two.I get what @Nasher means though in that having everything on one or two displays is a problem waiting to happen, as an example on my old 308 I had a glitch where the dash and infotainment unit went kaput on one journey and I had no idea what speed I was doing so I had to pull over to the hard shoulder and wait for it to fix itself.
At least if just the infotainment unit is on a screen you can still see what speed you are doing and control the heat etc
Indeed. Let’s not mention Ford S max clusters.Sounds like it's a problem that already can happen then, whether you've got screens or not
I only use the motors for here to be honest mate. Got other things more interesting going on than surfing this whole site. I just wish I was ignorant as you cause as they say ignorance is bliss.You two are like Mr Burns and Smither. Not figured out which is which yet.
Every thread lol
with embargos on us exports of semiconductor technology/CAD software(/ARM IPS?) , all with duel military use, verification and reliability of chinese car automotive electronics might be problematic,
(Is trump planning anything more forceful there - who are chinese suppliers currently. )
another reason to buy british/european/japanese
Fair however I didn't actually hit anything (Well technically something I guess but its not like I kerbed it) however I would expect a car to cope with "wear and tear" without damaging something like the wheels. I'd expect them to be robust enough to put up with the odd bits of grit and dirt without permanent damageName anything in life that has gone up in quality. Cost is the focus. To be honest though it’s a bit of an assumption to link that scratch to quality. That could have been anything you hit that would have marked any wheel regardless of age.
Valid point however it's not something I have experienced in cars that had standard spedometers etc beforeSounds like it's a problem that already can happen then, whether you've got screens or not
Good point as whilst the bodywork and overall interior seems to have gone down whilst there are the odd problems with slow infotainment systems its a far cry compared to what used to happen with the older Freelanders where you'd get a bit of water on it and all of a sudden the car wouldn't startIndeed. Let’s not mention Ford S max clusters.
Let’s be honest too. The one thing that has got massively better is electronics reliability
You're right, in the case for me both the digital displays went off however I guess if whatever went weird affected the actual spedometer system (I'll preface this by I have no idea if that would be the case as I never got an answer as to what actually went wrong on my car) then it wouldn't have mattered if it was a traditional spedo or a screenOne. Or two? The issue was one display only in a car. Most have two.
