- 18 Sep 2009
- Dormanstown.
The graph has me confused.
Why has it got i7 4770k, then i7 4770k IGP?
Using the iGPU to encode vs the CPU cores?
One with graphics card,one without.
That's what I thought, but then saying it's using more power than the i7 4770k is a bit sensationalist. It's using more power than the i7 4770k when using its IGP.
It is using more power though.
When both are using their IGP, it is, but why wouldn't it? It's misrepresenting the truth.
There isn't a i7 4950 none IGP power usage there![]()
The truth is the part is using your part and you are misrepresenting for some reason.
? It's no known dialect lol.Are you sure they're not using IGP encoding? I saw Handbrake update with OpenCL support the other day.
It's the only way to explain the power draw. Otherwise it makes no sense whatsoever.
Which is where our confusion was coming in, as it's only logical the GT3 would draw more power than GT3.
Don't you mean the desktop part is over rated and the Laptop is under rated?
Intels TDP ratings confuse me anyway, just look at 3770K to 4770K.
Overall that CPU looks really good, definitely something I'd want in a laptop, dat battery life.
But that's quite a heavily cut down GT3, but fits in the same TDP as my i3 does, which runs a crippled HD4000.
