- 29 Oct 2013
So i bought a new Motherboard, CPU and RAM a few weeks ago. Went from a Gigabyte EX58-UD5 and a i7 920 to a ASRock Extreme 4 and a 4670K and i picked up some Corsair Vengeance Pro 1600MHz 1.5v.
After a week of using stock speed i went into the BIOS and used ASRocks Optimized defaults for a 4.4GHz which in turn gave me a BSOD every time i tried to boot-up, so i went back to stock and searched online for an over clocking guide i used the one found HERE. I followed that guide and put all my sliders to that what it showed in the pictures and then i did trial and error from then on upping the Vcore by 10 and the CPU cache Voltage by 5 each time it threw me a BSOD.
I finally got it stable-ish and i say ish because if i run Prime95 on Blend it throws me a BSOD after about 10-15 passes but i can play Battlefield 4 for 7 hours (as i did yesterday) with no problems and my temps are only in the range of 60-65 on a load of 100% and 32-33 on idle. I'm running a H100 so i can push it further i just need to know if i have a good 4.4GHz and if i can tune any voltages to get a better Over clock.
I just want to know if i am doing something wrong do i need to change something else. I should also point out that i am using the A-tuning software that is shown in that guide, I use that to find voltages and then when i have good voltages i will put then in the BIOS then i can save that profile and if i ever wish to take the OC off i can just save to a profile and revert back to UEFI defaults. I have to point out that i have only over clocked once before and that was with my old CPU got it to 4.0GHz
I shall post some screen shots of what i have in A-Tuning.
. I shall post some screen shots of what i have in A-Tuning.
