Hi Guys,
Over the past few days I've been encountering weird issues with my GFX card (BFG 800GTX). I originally put this down to the possibility of an unstable overclock on my old hardware and have since bought a new E6600 and new mobo which still has the same problem (both overclocked and at stock).
This is the issue I often experience when playing video games or trying to run 3Dmark06:
http://axerite.com/images/eeeek.jpg
I've tried older and newer chipset and gfx card drives, systems I have used are as follows:
System 1:
Asus P5W-DH Dlx
2GB Gskill PC6400 RAM (mem tested ok)
E6600 @ stock and 3.4Ghz under Zalman cooler
Hiper 580w PSU
System 2:
Asus P5N-E SLI
E6600 @ stock and 3.6Ghz under TEC
Corsair 620w PSU
Temps in both setups are fine (CPU is 25 idle, 52 load overclocked) gfx is about 50deg idle, mobo temp is aprox 25.
Anyone got any recommendations or advice? I never used to have this issue with my X1900XTX, only been getting it since I put the 8800GTX in last week!
Cheers
System 1:
Asus P5W-DH Dlx
Hiper 580w PSU
System 2:
Asus P5N-E SLI
Corsair 620w PSU
Cheers
