HD2900XT temps
I believe this is it though i have never seen one in the flesh...
It may be the toxic version.
Biglunn said:
Its an Antec P150. Im thinking of having a pipe ducting air from the front intake fan to the graphics card fan
I found putting a fan on my stacker 830 below the 2900's intake fan lowered my max temps by 10c, i had to drill a few holes to secure the fan and some for better air intake but I'm pleased with it.
Near sure that got dumped and theyre now gonna be using that little watercooling setup they had for the x1900's.
yep thats what i heard but it would explain the three heatpipe version people go on about...
I have two 2900xt's in crossfire and on the 7.7's i idled at about 43 and load at about 60-70 now with the 7.8's i idle at about 61 and load about 70-75 according to ccc
Magnum_Force said:
http://www.game-addicts.com/wp-content/uploads/2007/04/ati-smackdown.jpg
If you look at the link you can just about see that the HSF has 3 heatpipes instead of 2.
On another note, my idle temps in AMD GPU clock tool are always lower than ATITOOL. Infact, I idle at about 51c in AMD clock tool, but when I fire up ATITOOL, my idle temp starts to rise.
I'm pretty sure ATITOOL is raising my temps somehow.
Yep thats because Ati tool enables the 3d clocks you need to go into the settings then to the HD2000 overclocking section and untick the switch to 3d clocks on startup.
imageview.php
Looks like ATi's reference cooler is 2 heatpipe so possibly HIS implemented a 3 heatpipe cooler? Those with the three heatpipe cooler what brand is your card, would be interesting to see if they are all HIS cards...
Another possibility is that since I only got my card a month ago there is a newer revision of the cooler...
